stilltrying
- Nov 5, 2012
- 5
- 1
Hi, I am new to Fiats and a couple of weeks ago bought a 1998 1.2 3 door with probable head gasket failure for my daughter.
The car has done 54k miles from new and one family ownership from new as well.
I got the car home removed the plugs and filled the rad with water, well it came pouring out of plug number one so definately a gasket failure.
Removed the head and sure enough gasket split between cylinders one and two plus cylinder one and a water way.
As my daughter lives a fair diatance away I decided even though the head looked level I would get it skimmed, bought a new gasket set complete with new head bolts and a new thermostat housing and stat, plus a new water pump, timing belt and tensioner.
Gave the valves a bit of a clean and lap, new valve guide oil seals, cleaned the block with some wet and dry, cleaned all surfaces and fitted the new head gasket plus all the rest of the new bits.
Torqued the head down to 30nm then 90 degrees then a further 90 degrees.
Changed the oil and filter topped up the rad, bled the system and turned the engine over with the coil packs disabled for a short while to get the oil around abit.
Re-fitted the coil pack wires and started the engine, ran nice for a while and got the heater in the car to run hot and the rad fan switched in and out so I thought all was good WRONG!! loads of white/grey smoke out the exhaust. Switched engine off and sulked for the rest of the evening, checked the water level the following day and it had dropped, refilled and tried again, first minute or so all was well then the smoke started again, ran it for a while, switched off and when cool enough checked the rad again and again it had lost water.
This evening I decided to tighten the head bolts a further 45 degrees to see if that would help but no it is still the same. When running the engine sounds fine but I'm now a bit stuffed having spent the best part of £100 on bits etc. and all to no avail or am I missing something?
I can only assume it is either a cracked head, cracked block or a rubbish gasket set, has this happened to anyone else? anyone got any ideas I can try to check what is wrong.
Sorry for the long winded post but am a little miffed to say the least.
