mistabig2006
- Oct 12, 2012
- 1
- 1
Had a look through the forum a few times and couldn't find a solution, so here goes.
I bought a 98 fx 60 selecta (automatic) due to a dodgy knee and since been swamped with problems.
First off the crank sensor packed in, found this out due to this forum. Replaced and fixed the issues. Since then the car was pretty rough so changed spark plugs, air filter, oil and oil filter. Since then it's been running well until the radiator fan stopped working and the heater fan doesn't heat up.
The heater fan blows cold on all settings, it just won't heat up at all. The radiator fan just refuses to come on at all.
All other electrics work fine as far as I can tell, and mechnically the car seems fine now.
My dad checked the fuses a few days ago and says they're all ok so is there anything else I should check before I need to put the car into a garage?
