Noticed this since I've had the Sporting. The gear ratios seem rather short. I know its a 1.2 16v with 85hp so to make it feel "sporty" it needs to have short ratios but these seem excessive. More like the box has been swapped for a Punto 55/60 box.
I'm comparing it to a Bravo 80sx which I had a number of years ago which seemed to have quite long gearing. This was the same engine. I converted that to run on a Punto 60box (bravo box was dead when i got it) which shortened the ratios a fair bit.
Basically, 70mph cruising in 5th is 3900rpm. The car will also happily accelerate to and hit the red line limiter in 5th which kicks in at around 110mph.
Now to me, that seems very short, esspecially considering Cinquecentos, with a few modifications, will manage 120mph+ before they hit the limiter.
Is this a standard box or does it sound like a shorter ratio box or potentially a shorter 5th? The car is standard so not sure a previous owner would go to the effort of sticking in a shorter 5th but there is easily potential for a Punto 55/60 box to have been put in as a replacement for the original.
Maybe I'm just being paranoid and the sporting ratios really are that short? Just seems too short for an every day car.
