Technical Gear Selection
spizzle
I've just fitted a replacement gearbox to my MK1 Punto, but now having trouble selecting the correct gears. First seems to high and I have trouble pulling away, 3rd seems lower than it is.
The gearstick feels very loose with loads of play.
Now, I had to undo the lever on the actual gearbox as I'd made a mess of removing the rod on the replacement and I think I've upset where the lever should be.
Would appreciate some help from anyone who has any experience of setting up the selection linkages.
Thanks for the advice guys sounds like it will be a right pain. Just had another look seems like the lever at the gearbox needs to be keyed onto the stud of the fork selector shaft. Trouble is each time I try to do this the shaft drops
