- Nov 9, 2015
- 64
- 64
Back again. Good and bad news.
Good news first
I could run MES and check more parameters
Battery now at rest is at 13v, a bit higher after charging it, and same value with engine running and warm, 13,96v.
Throttle position reset as per Workshop instruction and it works perfectly. Being at 4,2º at rest, flowing in paralel as the pedal, and always go back to rest position
Bad news. Lambda values are quite low, close to 0,90%, so poor mix what causes high CO levels. It should closer to 1, being 1 the perfect value and between 0,995 and 1,005 the optimal. I've checked it as well without air filter, just to try provide more aire to the engine. It has improved, increased to 0,93%, but still far from 1. At least I know that lambda is not correcting as expecting. Now I have to determine if it is because of the sensor itself or because of any other reason.
I couldn't drive it, so all tests have been done warm but stopped.
Next, test the old lambda sensor and see if there is any change in the values. I couldn't today either
Two videos. Sorry for the Spanish, I realized late it wasn't in English:
Lambda correction with air filter
https://www.youtube.com/watch?v=8IINxTBdY4Y
Lambda correction without airfilter, but full box installed
https://www.youtube.com/watch?v=nCZXlNmSQMk
Good news first
