Mar4ix
Member
- Feb 4, 2011
- 248
- 144
mk1 ., 1.2 8v punto. wondering, what is signs of blocked exhaust. would it be revs slightly jumping, and overfueling ?
everything new (used , but known good working condition) from (including) inlet manifold and up (sensors and injector), also vacuum pipes and lambda, new wiring loom, and ecu changed.
all cylinders has 15 bars compression .
no changes.
Would worn tappets cause irregular engine work ?
Possible bend crankshaft or camshaft ?
thanks.
no changes.
thanks.
