geohanson
Hi all, I have just filled up the Punto, waited until the pump clicked off, pressed it again, then it clicked off again, got back in the car and the needle wasn't at the top of the gauge. Its done this a few times, but as soon as I have set off, the needle moves all the way to the top, however this time it didn't. The fuel pump was only replaced about a month ago.
Would it be something causing the pump to click off early (I've used the exact same pump before and never had a problem) or a faulty sender unit. (Am I right in thinking this is inside the pump?)
The car has been stored for a while (about 6 months) without being moved. The exhaust had completely rusted through (it was stored inside) and the alternator seized so it wouldn't surprise we if something else had gone as well!
