Replacing springs and shock absorbers on 1997 Mk 1 with new.
I cannot work out the orientation of the shock absorber support bush; this is part no 7775940 on eper and is the bit with the locating pegs that bolts to the underside of the wing and has a single bolt holding the shock absorber and spring. This bolt is offset in the support bush so the front/back orientation is critical as it will alter the castor angle. Haynes on page 10.5 refers to diagram 3.15 re markings on the bush and also only refers to the left hand one; mine are new and I can see no markings on these or the old ones; unfortunately didn't note the orientation before removal (schoolboy howler)
any advice would be much appreciated
