Hi
Took the wife's Punto (98/R) Mk I 1.2 16v Sporting in for an MOT yesterday. Noticed last week that the front section (down pipe) of the exhaust was blowing and lack of power, so bought this section. Gave it to the MOT garage at same time, asked them to fit for me and carry out MOT. Car failed, but only on the emissions. Basically the chap said that the co2 was reading high/the hydrocarbons were extremely high but the lambda test was fine. Car sounds as if it is running on 3 cylinders, very lumpy and got to say that I did sense it was using more fuel last week, strong petrol vapors etc. They cant look at it til next week. I suggested lambda, but they said it passed the test. Also, have never managed to change 1 x spark plug in last 3 years as it is basically solid in there!! They will try to see if it is possibly this next week. Not sure if a dodgy spark plug/old plug would cause these massive emission readings? Not likely to be the front pipe they have fitted that is letting in air? Really grasping at straws here as I could spend money on (a) plugs, (b) HT leads (c) lambda sensor (d) filters (oil,fuel) or even worse (e) new cat??!?? Any advise you can give guys is very much appreciated. By the way, have noticed that the oil level is below the min on the dipstick, so will be replacing/topping up today but doubt it could be that? Cheers
