Fivestiles
- Mar 12, 2011
- 5
- 1
Hi Guys
I have a Punto 75 SX Mk1 (1995) which has failed it's MoT because of a worn bush in the main suspension arm. The exact wording was,
*** Offside rear (Main Front Bush) suspension arm rubber bush deteriorated resulting in excessive movement [2.4.G.3] ***.
I was told the whole arm would have to be replaced as the rubber bush is machine-pressed in . So could you please advise a step-by-step proceedure to remove and replace this Main Arm. I intend to attempt this myself but I need guidance on how to proceed with the nitty gritty bits . So far I have had no luck finding relavent help with this problem :bang: .
Your help (especially if with pictures), would be really appreciated :worship:
TIA, Fivestiles
TIA, Fivestiles
