Thread Tools
Old 07-03-2011   #1
Post punto 1.7 TD SX elec window, wont come down
hi all a few probs
1 , drivers elec window is up, wont come down, can here the motor spinning when push button up an down, im told the cables can snap,
is this a possibility or something more like gear box gears rounded off, any way of finding out can the elec motor be opened,/ repaired pasenger side works but goes slow last few inches of up - close..
2, how to tension either the power stering belt, timming belt , or the alternator belt, it squeals when engine cold first start, for a few minutes then no squeal, its difficult to pin point being so close to each other,, iv noticed that the squeal is constant ie it doesn't increase when revving, same as idle , is this a common fault ... 98 k on on milo got no service history at all or emitions report, 6mnth mot
iv also notice a small amount of black oil in the air cleaner box has saturated the paper filter on the left hand side viewed from front, the dip stick is just above the full mark, no sign of any engine oil leaks on the engine, doesn't seem to burn any not smoking at ex,, power seems good through the revs, pulls well up very steep hills in 2nd 3rd,, not shore what mileage i should be getting,, any pointers would be greatly appreciated,, thanks in advance, Paul....
Paul1966 is offline Reply With Quote Quote
Old 19-08-2015   #2
Malaysia
Re: punto 1.7 TD SX elec window, wont come down
Hi, looks like the microswitch that attached to the window switches are malfunction. Over the time, the oxidation layer on the microswitches caused connectivity failure.
You can dismantle the panel and get on to the micro switches, open the cover and give it a clean polish with folded sand paper.
My Punto Window resolved through this ways, after months of research.
All the BEST!
Martin Lim is offline Reply With Quote Quote
Thread Tools
(T) door replacement mk2 - elec versus man window bickley Punto (Mk2/2b) 2 09-06-2010 00:11
(G) passenger elec window... Ash1711 Punto (Mk2/2b) 1 03-06-2008 13:35
(G) elec window switches levemircento Cinquecento / Seicento 4 15-05-2007 10:28
Punto o/s elec window motor + Cinq haynes Manual home_slice Auction Watch 0 05-07-2006 17:23
(T) pass side elec window so slow going up sutty2tone Bravo / Brava 6 15-01-2006 12:52
