Technical radio not working blown a fuse?
jimbojimwj
i was looking at a blub in the courtesy light not working and the clock too wen i swithed the drivers light (think reading light) the radio went off i cheaked the fuse behind the radio but was ok i look at the fuse box where the drivers wheel is on right but none wat i can see
havent got manual so havent got clue
were the fuse would be and fag lighter dont work too
thanks in adavane
james
There is a fuse box under the bonnet as well as the one beside the steering wheel. Once you have taken the cover off you will see a diagram on the back which tells you which fuses are which.
And yeah you will have blown a fuse for the interior light and radio to go off because they are both on the same one, happened to me but not sure which fuse because it happened a day before it went to a garage for a service so let them do it
