david295
Established member
Date Model Recall
01 Jan 1998MkI built March '97-Nov '97Faulty seatbelt pre-tensioner.
01 Aug 200177,166 Mk 1 built 1/1/1993 to 31/12/1996(VINs ending 0010087 to 6023643) Recalled to check for corroded brake pipe, replace as necessary and apply corrosion protection to remaining pipes.
17 Aug 20013,055 Mk 1 built 1/1/1994 to 31/12/1995 Water ingress to driver and passenger airbag ECU can set them off. Water protection fitted to ECU.
01 Jan 20042016 MkII(VINs 51420 to 201384 4005830-41829005000094-5055134) Fuel Vapour re-circulation pipe may fall foul against air conditioning compressor resulting in damage and risk of fire.
30 May 1995Built: 01/03/1994 - 31/03/1995Some vehicles with alloy wheels may have been supplied with an unsuitable space saver spare wheel. If fitted, this spare wheel could cause interference with braking system components. VINs: ZAR17600006001149 to ZAR17600006010175.
31 May 2001Built: 01/02/2001 - 28/05/2001The steering column upper support bearing may be cracked. This could ultimately affect the directional control of the vehicle.
VINs:
ZFA188000000299008 to ZFA18800000359182 ZFA18800004273056 to ZFA18800004337762 ZFA18800005090823 to ZFA18800005112105 ZFA18800002200901 to ZFA18800002272327
01 Aug 2001Built: 01/01/1993 - 31/12/1997Prolonged exposure to the effects of road salt corrosion may result in perforation of the metal brake pipes and a consequential loss of braking efficiency. VINs: ZFA17600000010087 to ZFA17600006023643.
VINs:
