Hi guys,
i inherited a 98 punto 60 s.
i was driving it the other day and the heating stopped working. i knew from previous experience that this was a bad sign ( old cinquento)
anyway no temperature warning lights came on but i pulled over anyway.
i heard that the punto has problems with air locking in the heating matrix. so when i went to bleed the coolant system i discovered there was no coolant in the car. so i topped it up with coolant.
now i opened the bleed screw on the radiator and filled it up to the suggested level on the coolant resivoir. the heating came back on after running it for a few minutes. but there was signs of white smoke coming from the exhaust.
but i left it as i had not got time to investigate it further. so when i came back to it there was no coolant in the system again. and i cant see whee the leak is.
so i suppose my queries are....
if no temperature warning came on was the engine alright for running with no coolant for a that small amount of time?
does the white smoke signify damage to the head gasket?
is the any other bleed screws in the coolant system that i need to open to re fill the system properly?
is there any other possible faults causing my coolant to dissapera other than a leak?
sorry for all the questions just annoying me as the car was "serviced" before i got it and it was running fine for the last 2 weeks i had it.
P.s extra info. there seems to be staining on the inside of the coolant resevoir. like rust. is this from the coolant system?
Thanks in advance
Martin
Thanks in advance
Martin
