Technical gt clocks
Technical gt clocks
jigg
Shrewsbury, Shropshire
i have a punto mk1 1.1 55 will i be able to fit the gt clocks with out doing to much wireing any guides will be great please guys
Look for the ones from an sx elx or sporting from a scrap yard and also get the temperature sender from the back of the block (1.1 or 1.2 8v only). You will also need one of the connectors to "butcher" to get the metal connector as you need to run an extra wire to the ecu loom. There is a guide on here on how to do it.
