General punto gt (take or keep on head to get to turbo)
zlawlaw
leamington spa
hi there people just asking if do u need to take the head off to get to the turbo on a punto gt .and also dose any one know the head bolts order to take the head off thanks .
not 100% but just undo the exhaust and inlet manifolds, undo the connecting piping etc. Never heard of any (l4) car you need to take the head off to get to the turbo.
The turbo is mounted on the exhaust manifold there should be no need to touch the cylinder head bolts. The manifold studs/nuts can be seized - Dont force them apply heat with a gas torch or arc weld to free the seizure. If you force them and any snap you will probably have to remove the head to fix the broken off studs.
Head bolts removal order is the reverse of the fitting order. You can do a search for that.
When you put it back onto the engine make sure the pipes are 100% clean of debris. Any grains of carbon or dirt hitting the turbo will ruin it. Turbos are simple things but they spin at incredible speed and easily damaged.
