Hi all,
I've had problems with under the bonet knocking since I brought my 97 p reg punto 55 s.
After lot's of probing around the engine using the screw driver in ear and on engine method, Me and my dad have come to the conclusion that it's the camshaft or camshaft bearing's, the noise and knocking is most heard and felt on the screwdriver at the coil pack end.
After looking about on the internet and getting in touch with different engine reconditioning place's etc, It seem's you can't get camshaft bearing's for my car, and apparently the camshaft just slots into the head
I'm hoping this may fit in with the power loss, flat spots, and engine rattle under load. If you floor the pedal in any gear other than first, It's response is dead and heavily delayed. I was just thinking that if the camshaft is moving in it's bearing cups up down or left or right it may not be shutting or opening the valves long enough or too long? Timing is correct, new leads and plugs have been fitted. Head gasket was done, but problem was there before and after, every 12months she get's fresh oil and filter's. Throttle body has been replaced, fuel filter, coil packs, all too no avail. But she is high mileage over 100,000.
Anyway I've decided that the only option I have is a cylinder head transplant? My local scrap yard has suggested around £40 for another full head. When I get one I will be cleaning what I can valves etc and will be having the head skimmed before fitting it too mine.
What advice can anybody on here give in looking for a donor head?
Mileage on the donor car?
If once the rocker cover is open (the donor car), Its nice and oily?
Also have I got to have the same model of punto head? i.e 55 s only.
Thanks in advanced for reading :worship:
