i've still got the old engine and all the manifolds, powersteering, pumps, etc. is it a case of just bolting everything to the mk2 engine and fitting straight in, also the cam blanking plate are these the same. thanks
Yep it should be a straight fit when its all connected, the only complicated bit is getting the exhaust made to suit. Forgot to mention that system has 2 oxygen sensors, you need to block the downstream one with an old sensor.
You have to make up your own blanking plate, seal it up with silicone and use the original bolt to hold it in place
Mk2 exhaust manifold only, as this has the cat built in to it. The Mk1 manifold has a different stud arrangment and may look similar but don't interchange (been there done that) You need to make up the exhaust from the cat back
