im Axle Specialists
Old 07-06-2010   #1
Mk1 Punto Owner - 51 Mpg
MadMan0's Avatar
MadMan0 has donated!
What coolent do you use?
I have a 1997 mk1 55 s in need of a coolent change, currently got a green coolent in, no idea what it is... No idea what to replace it with...
which coolent Do you use?
(If every one says the model of car & coolent they use, so anyone who looks for advice on coolent can use the same thread )
MadMan0 is offline Reply With Quote Quote
Old 07-06-2010   #2
Re: What coolent do you use?
Rule of thumb is don't mix colours. If doing a coolant change including draining and flushing, it shouldn't matter what you use (provided that it is a proprietary antifreeze coolant that you mix with water). Strength of mix determined by climate (Scandinavians tend to need something a little stronger than UK!)
red
red is offline Reply With Quote Quote
Old 07-06-2010   #3
I use the red coolant (5 years life I think). But I always fill, drain and bleed it it a few times with clean water to shift as much muck as possible. After that its OK to use red or blue.
Unless you suspect the radiator is elderly its also worth using a flushing chemical.
DaveMcT is offline Reply With Quote Quote
Old 07-06-2010   #4
m20b25 has donated!
Ireland
Paraflu blue. 50 - 50 coolant to water mix red paraflu dosent work well on my Tempra or the Bravos and is generally for Alfa Romeos
The ultimate driving machine, the real M20B25
"Ride me sideways"
VAN-dalised Bravo
Small, fuel economic, environmentally friendly Alfa
I am this gombeen
m20b25 is offline Reply With Quote Quote
(G) Coolent loss FRESTER Multipla 0 30-12-2009 12:25
(G) Air locks in coolent kevincox1987 Punto (Mk2/2b) 3 04-10-2009 01:38
(T) isit ok to top up coolent like this? kaosNW Bravo / Brava 10 23-01-2009 15:54
radiator coolent veltsy Newbie Central 2 13-08-2008 20:54
(T) Coolent Silver_Sei Cinquecento / Seicento 2 14-09-2003 04:32
