going to be changing a friends discs and pads tomorrow on a mk1 punto 75, not the same friend who smashed a manhole, we likes our fiats
just after a lil advice really, i used to have a mk1, and a disc change is pretty much the only thing i never did!! (did LOTS of others including clutch, timing and all the trimmings, HG services and break pads) and i no longer have my haynes, went to my brother when he inherited my punto. (which is now many miles away and still going )
is there anything that cant be solved with common sense and itallian thinking that im likely to encounter tomorrow??
IIRC using Mintex discs and pads OEM replacement, all brand new of course
im guessing:
- remove wheel
- Remove pads
- compress cylinder & bleed out some old brake fluid
- somehow remove caliper (never looked at how to do it, pointer would be great)
- Remove disk
- clean up everything there
- give new disks a quick going over with sandpaper???? (have been told some disks have a coatign which needs to be removed)
- bolt on disks
- reattach calipers
- fit pads
- wheels on
- test drive and find he has spongy leaky breaks that dont stop the car, crash into a ditch fortunatley full of marshmallows
(all of the above except the last for those not familiar with sarchasm)
also is there any special tools ill need, aside form the normal clamps, sockets, wreches, spanners etc
thanks guys and or gals!!
im guessing:
- remove wheel
- Remove pads
- Remove disk
- bolt on disks
- reattach calipers
- fit pads
- wheels on
