Copied from other thread (didn't realise you had started a dedicated thread)
You want to head over to
www.puntosportsclub.co.uk/forums and take a look at the projects page. There's a lad over there by the name of 'Superman' (Dan) that had 226 BHP out of the GT. He's now got rid of his Puntos in favor of an Evo (the Mitsubishi type, not Fiat), but still hangs around the forum and is most helpful.
Typically though, the recipe goes somewhat like...
Bigger turbo (Owen's Developments modified Garretts seem to be the turbo of choice)
Turbo hardware (standalone dump valve, boost controller etc...)
Aluminium front-mount intercooler and piping
Dr Evil turbo elbow (search that forum for 'Dr Evil' to have one made)
Power on the Road SEB map-on-a-chip (search forum for 'Mr Hans' for supply, he's a bit of a argumentative bighead at times, but knows his stuff)
Bigger aluminium radiator
Bigger injectors (size depending on stage of tune)
Coupe fuel pump to feed larger injectors
Forged pistons
Forged con-rods
Lightened and balanced crank
ARP bolts
Uprated cam
Lagged Mongoose exhaust
Pipercross induction
With that little lot, you'll have a car with far too much power for its chassis to handle, so you may wish to consider...
Uprated springs and dampers (such a diverse topic, I shall not discuss here)
Uprated anti-roll bars (Only Eibach do these for the GT, and there's only like 100 in the country. Balance Motorsport claim to be able to get hold of them new though)
Strut brace
Uprated tyres (for fast-road, sticking with 14" is probably best)
Uprated brake pads (for fast-road, the GT3 Bendix (not GT1 Girling) calipers and 257 x 20mm discs up front are fine, just invest in good pads like Ferodo DS. Aluminium alloy rear calipers are available as an option for reducing unsprung weight at the rear.
If considering track-day use, add the following...
Coilover suspension
Race seat with four-point harness
Roll cage
Uprated front brakes (will require 16" wheels with 195/40 R16 tyres, Brembos 4-pots from the Coupe with custom brackets and Coupe discs are a common upgrade, less common is a Wilwood setup, and if you are feeling flush (£1500), AP Racing do an excellent front kit for the GT. Exercise care with the Wilwoods since they are not dust sealed)
Plumbed-in fire extinguisher
Quaife LSD (there is a group-buy for these on PSC, but don't expect to get your hands on one anytime soon)
