Hi guys
I was wondering if you would be so kind to have a look at a couple of questions, as I am a bit desperate.
I am trying to fix my 1.2 8v 1996 punto and the problems are the following
- Temperature gauge won't go up to the 9 o'clock possition unless sitting in traffic and outside temperature is not too cold, when it's warmed up then traffic starts moving or I do motorway then the needle will go back down to maybe the 7 o'clock possition - I am suspecting open/faulty thermostat? heating works fine and I have already changed coolant, cleaned with radflush and bled everything. I am assuming that when the thermostat is working fine then the needle needs to be at 9 o'clock regardless temperature or driving conditions right? if that is the case then I think I will change the thermostat.
- Revving up spontaneously - when starting the car sometimes the red injector light is on or it will come on after a while - then it goes of - intermittently - then at a given point the car starts revving up between let's say 1500 and 3000 revs up and down, I have noticed that when the car is warmed up the revs will stay statically at 900 most of the time, but it sometimes revs up as well when warmed up not only when cold. When driving for a long time in the motorway then the light does not come on normally - only when backing off the throttle while going downhill. Strange but the car does not rev up when the red injector light is on and revs are steady at around 1.500. Sometimes it sorts itself up and revs stay at 800-900 mainly after a long trip with engine well warmed up.
- I tried plugging off the lambda sensor - but it revs up anyway - i suspected the lambda sensor might be faulty but I am unsure if unplugging the lambda should makea difference? Also when I passed the MOT all emissions parameters passed with flying colours.
- I am also suspecting the trottle body or sensors in it - apparently this is a commont fault?
- It can also be a vacuum leak but if that is the case - would I get the dreaded red light injector? which tubes should I check for leaks? I suspect not as if it was a leak then it would do it all the time but sometimes idle just works fine, so I suspect something electronic rather than a leak?
I have been offered a 60s lambda and throttle body - do you happen to know if they are the same as in the 75sx? I can also get the temperature sensor if I need it. they are both the 1.2 8v engine but I can't check if they are exactly the same as I don't have any photos of the one being offered.
I have also seen in the forum water temperature sensor - not sure if that will have to do with my gauge temperature not rising properly - I have seen that the sensor used for the gauge in the dashboard and the one in used by the ECU are different? if there are the same maybe that's what is creating trouble. How can I check? just by disconnecting the sensor?
Thanks guys for your help.
