Old 03-01-2010   #1
Question Another misfiring 55S
I've been looking at the threads and guides trying to sus this one out - the car in question is a '95 1.1 55S. It's running rough and has just about enough power to make progress downhill with the wind behind it.
I've checked the plugs and all appear OK with exception of slight discolouration on external ceramic of No4. Checked resistances of coils against Haynes values and found both LT resistances to be higher than expected (0.2 ohms), one reading 0.4 ohms, the other 7 ohms.
After reading the forum guide I tried starting the car with each coil disconnected. Would not start at all with either coil, so reconnected both, started up, then disconnected each in turn with the engine running (and thick rubber gloves!). As soon as either coil was disconnected, the engine died.
Anyone got any ideas where I should look next?
Station Master is offline Reply With Quote Quote
Old 03-01-2010   #2
I like to be different!
bredsticz's Avatar
Trader Rating: 1
bredsticz has donated!
Re: Another misfiring 55S
I'd suggest doing a compression test to make sure the engine it self is t good condition. Also your coils may be going! :P
Thanks Station Master thanked for this post
Any MK2 punto parts needed? Let me know!
I have 2 punto's worth of parts for sale
bredsticz is offline Reply With Quote Quote
Old 03-01-2010   #3
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Don't disconnect the coils while running, disconnect and replace each spark plug lead in turn, noting which, if any, made no difference to the poor running.
I guess the management light is on.
SPD
Old 06-01-2010   #4
No management light on. I'll scrounge a compression tester and try the plug leads in the meantime. Thanks.
Old 09-01-2010   #5
Is there an idiots guide to compession test available? I've found one for a Mk1 Cortina (!), but some expected figures for the 55S Punto 1.1 would be handy.
Old 09-01-2010   #6
OK, I should have looked in the haynes before posting!
Old 11-01-2010   #7
Compression test showed 160 on 1 & 2 and 20 on 3 & 4. Head now off and sure enough there's a big hole in the gasket beween the cylinders.
Old 11-01-2010   #8
reddy4bed has donated!
For future reference, 1 & 4 also 2 & 3 plugs run in series with each coil, so disconnecting any one will also disconnect its partner.
reddy4bed is offline Reply With Quote Quote
Old 12-01-2010   #9
Trader Rating: 1
Quote Originally Posted by Station Master View Post
out of interest, did you not have any mayonnaise under the water cap to indicate the gasket had gone?
MK1 1.2 16v Punto Sporting
MK2 2.0 20v 155 Bravo HGT
http://nedge2k.com
nedge2k is offline Reply With Quote Quote
Old 12-01-2010   #10
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by nedge2k View Post
Unlikely, as the gasket had gone between cylinders, not between a water way and an oil way.
Head gaskets can 'go' in so many interesting and different ways!
SPD
Old 12-01-2010   #11
Autotest Special
rallycinq's Avatar
Trader Rating: 1
The spark plug test would have found that too.
SPD
(G) still misfiring!!! tubbs2009 Punto (Mk2/2b) 1 06-03-2009 10:06
(T) Still Misfiring! help please kevzy Bravo / Brava 11 18-02-2009 12:17
(T) misfiring (i think..) Bushboy Cinquecento / Seicento 13 06-12-2004 19:07
(T) misfiring? Diesel20 Stilo 2 15-11-2004 18:49
