Station Master
I've been looking at the threads and guides trying to sus this one out - the car in question is a '95 1.1 55S. It's running rough and has just about enough power to make progress downhill with the wind behind it.
I've checked the plugs and all appear OK with exception of slight discolouration on external ceramic of No4. Checked resistances of coils against Haynes values and found both LT resistances to be higher than expected (0.2 ohms), one reading 0.4 ohms, the other 7 ohms.
After reading the forum guide I tried starting the car with each coil disconnected. Would not start at all with either coil, so reconnected both, started up, then disconnected each in turn with the engine running (and thick rubber gloves!). As soon as either coil was disconnected, the engine died.
Anyone got any ideas where I should look next?
