Technical Punto Mk1 Fuel/electric mystery
terry6789
Punto 60s 1998 - complete power loss while moving, would not restart though engine turning over well.
Battery charged, good sparks at all plugs, fuel in tank, fuel filter clear, fuel coming from injector, air filter good, TDC sensor not faulty, multiple relay OK, coils OK, timing belt on and not damaged/loose , key code reading OK, ECU warning light not remaining on.
Any ideas ?
Any ideas ?
For any petrol engine to start, you need:
Fuel (at the correct time)
Spark (at the correct time)
Compression
I'd be looking at the valve timing next.
Dave.
