General is it possible to put Fiat Stilo wheels on a Punto mk1??
Puntoblunt
Hi guys i was jus wondering if it is possible to put Fiat Stilo wheels on a Fiat Punto Mk1....does any1 know whther it has the same number of bolts...
Stilo wheels on a Punto, is it possible???
Mine fit ok
I have 17's, but already had the arch work done.
The only thing I had to do was fit a 3mm spacer on the rear hubs as the wheels sat/touched the rear subframe.
Rob
Nice one Rob thats a great example man.....ur ride is lookin good....ic u have the right idea...they r the wheels i was thinkin of puttin on mine....so u had to put 3mm spacers on the rear hub....where did u get tha done...do u think u can get that done at any tyre place??
215 tyres wont go on, 205 is your max but make the car handle badly..
in an ideal world you have no more than 185 tyres so not to hinder the performance of your car, however the J of the wheel sometimes make this not possible, however you can have 195 profile tyres on any of the modern fiat wheels as they are most 6j or less..
topics like this with the responce they get make me laugh..
Cheers mate for the comment.
I bought the spacer from a motor store local to me & fitted them myself.
Used a bit of sticaflex to hold the spacer to the hub so when you remove the rear wheel the spacer doesn't fall off & when refitting the wheel its easy to line up.
Rob
