Technical Is Mk1 1996 Punto 55SX OBD II Compliant?
lee_gti
Strood, Kent
I have a Mk1 1996 Punto 55SX which as people may have seen from a previous post has failed its MOT on emissions and I am in the process of deciding whether or not to scrap.
But due to a post from another member I am now looking in to maybe repairing the car if I can find the fault and I was wondering if the car is complaint before I spend money on an OBD II reader.
Is there something before OBD II which may be relevant to this model?
mk1 puntos are Fiat 3 pin, only obdII are midway through the mk2 range..
mine is 11/2000 mk2 and is not obdII compliant..:p
My HGT is Y reg how can I check if its OBDII compliant? (sorry to hijack the thread!!)
There is a thread on here somewhere with the diagrams etc to build a code reader for the mk1s (believe its in the cinq section). You need a laptop with a serial port though.
mine is w reg and has a 16 pin female pluf in the fuse box, does that mean any 16 pin reader will work?
