Old 23-07-2015   #31
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
Re: Cam Belt timing
Mmmmm, indicative of running rich. Try cleaning them up and re-gapping them (0.9mm from memory but look it up) - see if that makes it start and idle better - and if it does do resistance test on the coolant temp sensor
Finn - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
Old 23-07-2015   #32
flisko has donated!
Re: Cam Belt timing
Quote Originally Posted by blu73 View Post
coolant temp sensor is 21 years old probably still original, but i dont think that would case problems in starting car
i changed spark plugs on 28.10.2014 ngk bcpr6es, warranty on plugs?
flisko is offline Reply With Quote Quote
Old 23-07-2015   #33
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Re: Cam Belt timing
no i don't think it will either, but it could make it run rich all the time which would eventually coke up the plugs to the point of not sparking properly... If that was the case cleaning and re-gapping them it would start ok but still run rich..
So my point was to clean them and gap them and see how it starts - that on its own could be the issue. Then look at the temp sender as that would be the first thing to look at for a reason for it to run rich.
PS> you don't have to quote me every-time you respond you know
Old 24-07-2015   #34
flisko has donated!
Re: Cam Belt timing
lambda and plugs are all dark
can that be cuz of bad temp sensor and running rich all the time?
do i have to drain antifreeze to change temp sensor
Old 24-07-2015   #35
flisko has donated!
Re: Cam Belt timing
mk2 lambda fit mk1 ? i know i will have to rewire, but will it work properly?
Old 24-07-2015   #36
flisko has donated!
Re: Cam Belt timing
changed everything electrical related but its still same
what else can it be
Old 28-07-2015   #37
Re: Cam Belt timing
Have you put the crank pully in the right position?
hf turbo is offline Reply With Quote Quote
Old 28-07-2015   #38
flisko has donated!
Re: Cam Belt timing
Quote Originally Posted by hf turbo View Post
you mean that little pip? its in right possition, it suddenly started to behave like this, before it was more or less fine
Old 29-07-2015   #39
Cam Belt timing
Yes that's the one mate
Have you got a spare set of coil packs
Old 30-07-2015   #40
bluejohn125 has donated!
Re: Cam Belt timing
This thread is confusing and not really going anywhere, mostly because you hijacked someone else#s ancient thread!
Start again and explain the spec and condition of the car, what you have observed, and what you have tried.
I have had similar things with a 1995 Tipo 1.4 and a 2001 Brava 1.2, generally it is sensors / wiring / air leaks that confuse the ECU or the fuelling.
The Tipo had an intermittent starting problem that was traced to the temp sensor and also it's flaky wiring. The Brava had an ECU light issue and rough running which was an airleak / crack just upstream of the 2nd lambda sensor.
bluejohn125 is offline Reply With Quote Quote
Old 30-07-2015   #41
Re: Cam Belt timing
Change the coolant sensor, cheap and fairly easy (may damage the old one getting it off with a socket...). No need to drain coolant I think, just a small leak.
Replace the damaged exhaust section, should be cheap and easy on your Punto. Avoids the lambda getting a lean (high O2) reading and telling the ECU to add more fuel.
Get the ECU fault diagnosed, it will probably give a temp or lambda sensor fault.
Old 30-07-2015   #42
flisko has donated!
Re: Cam Belt timing
i changed ht leads, coil packs, temp sensor, spark plugs, disconnected lambda and its same, rly hard to start and rough idle + some sort of metal clunk in engine when applying more gas while driving and it has almost no power
as said only error shown in mes was lambda
need to buy compression tester to check if its head gasket
Old 30-07-2015   #43
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Re: Cam Belt timing
metallic clunk under load worries me most from what you have said... does it turn over nice and easily and smoothly if you turn the engine by hand from the crank (it will be hard to do without removing spark plugs first).
Old 30-07-2015   #44
flisko has donated!
Re: Cam Belt timing
yea engine turns smoothly by hand
and its not that hard to turn even with plugs still inside and car in neutral
Old 01-08-2015   #45
flisko has donated!
Re: Cam Belt timing
is there something else i could try before i take head off, apart from compression test
(T) cam belt and timing zammo Stilo 5 24-03-2008 23:51
(T) DIY timing belt (cam belt) shiningliao Stilo 10 27-01-2008 08:58
(G) Cam Belt / Timing Belt query. amanda40 Marea 5 14-01-2008 22:09
(G) Cam Belt Timing GavinPearce Bravo / Brava 4 30-08-2007 14:20
(T) Timing belt / Cam belt? edmundo Punto (Mk2/2b) 5 26-06-2007 16:53
