Technical Gearbox drain & fill points
77jm
Can anyone tell me where the drain & fill points for the gearbox are on my 95 1.6 90 Cabrio?
Can see only one allen nut about halfway on the front - seems too low for fill & too high for drain.
Nice one!!!!!
Anyone know where the drain point is or shall I just top up. Will mixing oils matter? The oil has probably never been changed.
wavestar gave you info about the drain point.
As said the one you a refering to is the fill point.
Why is the gearbox oil low? if its lost some you must have a leak somewhere.
