General Front Wheel Bearing on a punto mk1
Warrington
My Car failed the mot on the Drivers front wheel bearing as it has some play.
What size is the nut?
How easy is it to fit a new one?
its not too hard, i think the nut is a 32mm, it needs replacing. as for the bearing you should be able to get a non genuine one for around £15. if you take the hub off and take to a garage they will press out the old and press in the new bearing and charge you about £5 then you just need to put it back together.
