7 77jm New member Joined Nov 24, 2008 Messages 39 Points 21 Mar 9, 2009 #1 Having a few problems with my electric hood. The motor is working but it requires a substantial push manually to get it moving. The fluid level is OK - any ideas?
T tez9381 TEZ Joined Aug 2, 2008 Messages 52 Points 14 Location manchester Mar 10, 2009 #2 make sure the bar on the pump is pointing up they usually drop down and all the pump does is pump the oil round in a loop
OP OP 7 77jm New member Joined Nov 24, 2008 Messages 39 Points 21 Mar 11, 2009 #3 Many thanks!!!!! Mine does not seem to point upright but was loose and now works perfect now it is tightened up
