General what are my lights?
rholtby
bloody car :@
Hertfordshire
im looking to replace my side lights but i dont know what type of bulb i need, ive got standard punto lights. can anyone help?
thanks
thanx i just ordered some of the quad bulbs, will post pictures to show difference when they arrive.
Hi mate,
You will probably need an in-line resistor for each bulb if you dont want the bulb failure warning to be on all the time.
Alan
i have them and its fine without resistor:confused:
Ah fair do's ive not used the ones from autobulbs direct, but normally if you put bog standard LED bulbs in a Mk2 or 2b sidelights you get the bulb failure warning light up.
They only draw less that 1w compared to the 5w of a normal filament 501 bulb. Normally it sets it off, but obviously not in this case.
Alan
EDIT: its no biggie if it does anyway, just fit one of these each side. http://www.autobulbsdirect.co.uk/led-resistor
Alan
cool.
I fitted these and no problems so far touch wood.
http://www.autobulbsdirect.co.uk/501-led-extreme-power-15w-360-degree-c-612-p-1-pr-17114.html
(y)
