baxter82fiat
- Jan 25, 2009
- 4
- 1
It won't start, was running perfectly, infact is like new! It's done 30k and serviced more times than you can shake a stick at.
But now for some reason it wont start, wont even try to turn over, just silence on the key turn.
When checking the engine I also noticed mayo under the oil cap, the car hasn't shown any signs of over heating and the water level is fine as is the oil level... Which makes me wonder if the head gasket isn't the issue? Also it's low mileage!
Battery seems to be ok, everything in the car works fine, lights are very bright and the wipers are moving at their normal speed etc.
Any ideas?
Thanks in advance!
Any ideas?
Thanks in advance!
