Thread Tools
Old 04-11-2008   #1
How Can I Read Fault Codes On Mk1 Punto?
My daughter's got a R reg 1.2 8v Punto 60 and i want to access the fault codes stored on the ECU ( if any). Can the cheaper scanners read them with the right connector lead (3 pin), Or is it only the dearer ones that can?
I have a 3 pin lead to 16 pin adapter but can't find any scanners that can access the codes on the Mk1, I also have a EOBD scanner that reads the codes on my wife's Mk2 but it's not capable of reading generic codes,, If any one can point me in the right direction please do...
jonnyfix is offline Reply With Quote Quote
Old 20-11-2008   #2
iancozens1 has donated!
Re: How Can I Read Fault Codes On Mk1 Punto?
as far as i know the fault codes can only be read by the fiat examiner
iancozens1 is offline Reply With Quote Quote
Old 20-11-2008   #3
BRUM!!
maddogmorg's Avatar
maddogmorg has donated!
Bolivia
________
(________)
maddogmorg is offline Reply With Quote Quote
Old 21-11-2008   #4
reddy4bed has donated!
The interface required is relatively simple to build. Software is available free on this forum. Bloodsucker wrote some s/w way back on the cinq section.
https://www.fiatforum.com/cinquecent...project-6.html
Tony.
reddy4bed is offline Reply With Quote Quote
Thread Tools
(G) Read fault codes on Marea 1997 Scklein Marea 11 29-04-2009 21:39
(T) Punto 1.6 8V ECU Fault codes? andrewb Punto (Mk1) 4 26-03-2009 01:54
(G) punto mk1 cd playewr wiring coloer codes djrogue Punto (Mk1) 1 10-05-2008 18:30
(G) How do i read punto mk1 fault code? punto55sx Punto (Mk1) 10 20-02-2008 13:30
