Hi
Novice here so excuse me if I'm not making myself clear.
I have in the last 2 months had a new head gasket, 2 suspension arms replaced and had a broken valve replaced i think on the head gasket!!!
When I'm changing gears or acclerating the engine makes a noise similar to the noise made when changing to the wrong gear and the engine struggles initially. The noise happened prior to the valve going which eventually killed the car temporaraly. Its now back and slowly getting worse. Acclerating is still ok and it doesn't struggle yet, but the noise makes you think it will any minute now
Can it be the valve again. I really hope not. It cost me £200 last time inc labour and that was only just over a month ago
Any help you can give me would be great
