FIAT Auto Specialist Team
Old 23-07-2008   #1
mk1 punto cigarette lighter not working
sorry just posted this twice once in the panda section by mistake sorry again,
ok then heres a strange one for you, had our car stereo nicked and they cut the wires leading to the stereo instead of taking the clips anyhoo, they blew fuses and i have replaced them all, BUT the clock works and interior lights etc but the cigarette lighter wont work at all nothing nada. i understand from the manual that they all come from the same fuse leader but nothing, and now using a satnav isnt really possible as cant keep it running on mains.
any idea as i have racked my and the manuals brains
thanks in advance
Treefingers
mk1 punto 75
treefingers is offline Reply With Quote Quote
Old 23-07-2008   #2
Re: mk1 punto cigarette lighter not working
If they cut the wires for your radio they may have also cut the wire to your lighter socket, particulalry likely if they have a common earth or power input. As they share the same fuse I assume they share common wiring?
Don't know how easy it is on the mark 1 but if you can pop the lighter socket out you could measure the voltage between the +ve input and a good earth. If that is okay then measure the resistance/do a continuity test for the -ve electrode. that would help identify where the problems is.
Hopefully a more experienced member will be able to give more definitive advice.
mrcarrots is offline Reply With Quote Quote
Old 23-07-2008   #3
MK1 Punto Mad
01goddak's Avatar
01goddak has donated!
Talking Re: mk1 punto cigarette lighter not working
im pretty sure it is a common wireing loomwat style dask do you have ? is your stereo at the top or bottom ?
ill try and find out at work today ! then let you know later if no one else has managed to help you !
01goddak is offline Reply With Quote Quote
(T) Cigarette lighter... SlinK Punto (Mk2/2b) 8 24-10-2008 00:15
(G) cigarette lighter vultus Punto (Mk2/2b) 1 19-07-2008 11:57
(G) punto mk2b cigarette lighter socket DaDudee Punto (Mk2/2b) 1 20-09-2007 11:17
(T) New Brava, cigarette lighter not working DrGonzo Bravo / Brava 3 20-02-2007 20:14
(G) Cigarette lighter not working. pji Punto (Mk2/2b) 9 03-12-2006 12:34
