philmellor
I have a 1.6L 1994 punto 90 ELX softtop and its making a strange noise!
It started after a brake failure. I had to handbrake it to stop. Local mechanic came, fixed the problem with the brakes (leaky rear cylinder) and rekoned I'd flat-spotted a tyre (causing a rumbling noise). I went to the local garage (Feu-Vent) and got a new Contenental, which has made no difference.
The noise is hard to decribe as it changes:
UNDER ACCELERATION: Noise is a regular 'thump' and only occurs during mid-range revs.
COASTING/SLOWING: Noise becomes more regular with a metallic sound until low speed then disappears. Can't tell if the noise is effected by braking, but it seems likely.
The noise is definetley affected by road surface. The rougher the surface the worse it sounds. A friend says it sounds like the "bottom of the car is coming off".
It seems to be getting worse.
I have jacked it up, checked wheels, suspension and brakes. All seems ok.
Does anyone have any ideas? Don't want to take it into a garage without a clue, otherwise I'l just get ripped off out here (Spain!)
Thanks!
Thanks!
