Hello everybody,
I need some help with the following..
My Punto (MK1, 8V, 60S) broke down a couple of days ago. The problem: engine will not start. The starter motor turns the engine but the engine just doesn't come to life.
I have breakdown assistance so I called it, but the mechanic couldn't figure out what was wrong either.
Things that have been checked (by mechanic or myself) are:
- CODE lights up and disappears (as normal)
- Injector light lights up and disappears (as normal)
- When key is turned in ignition the fuel pump can be heard working
- Starter motor turns engine
- As engine turns alternator turns as well (so not stuck as in another post)
- Full tank of fuel
- Fuel cut off switch is depressed (normal position)
- Distributor works/spark plugs work
I had a look at previous posts and some people mention RPM sensor or Lambda sensor. Could failure of either have the effect described above?
Is it possible to check if either has failed without buying replacements?
Can anybody think of something else? The mechanic mentioned possible low fuel pressure but how can I check that?
The car is quite old and I have spent a lot of money on it so I am trying to avoid another expensive garage bill..
Mark
- Full tank of fuel
Mark
