im Axle Specialists
Old 30-07-2007   #1
Unhappy Punto 60s clutch juddering!!
Hi guys! My MK1 punto 60s has a juddering clutch in gear one when the engine's cold. This problem is less obvious after warming it up by running some miles or shifting to higher gears. Took it to two garages today, the guy in the first garage without even looking at/driving it told me it's the clutch wearing out and I'll need a new clutch. The second garage told me it's a leaking crankshaft seal that spills engine oil into the clutch assembly. Any idea who's right, although i'm sure either way they'll need to take out the clutch...
FePunto is offline Reply With Quote Quote
Old 30-07-2007   #2
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Re: Punto 60s clutch juddering!!
Both potentially could be right! First things first though, could well be that the clutch is contaminated with something, such as engine oil. You could try slipping the clutch and accelerating hard...not great for the clutch, but if it is just a bit of contamination it may well ware it off. Could be worth a try!
If you see a problem post, please click the report button
a1ant is offline Reply With Quote Quote
Old 30-07-2007   #3
Just had to get my 60s clutch replaced recently because it had worn out. Pedal was vibrating quite a bit and juddering.
RichieUK is offline Reply With Quote Quote
Old 30-07-2007   #4
Thanks! I'll try slipping it hard today after work to see if it works!
Quote Originally Posted by a1ant View Post
Old 30-07-2007   #5
How much did it cost you? The cheapest quote i found in Cambridge so far is 320 quid.
Quote Originally Posted by RichieUK View Post
Old 14-09-2007   #6
my punto done the same judder when cold had the clutch replaced but it's still juddering, it might be fuel prob as soon as mine is up to temp judder stops and its ok til next morning
pushthepunto is offline Reply With Quote Quote
Old 18-09-2007   #7
i recently had our punto mk1 clutch replaced.the first garage quoted 300,but a bloke in a small garage who come recomended by a mate charged 80 labour,plus 50 for a clutch kit.it was the thrust bearing that was squealing in our case.
martyfarty is offline Reply With Quote Quote
Old 10-01-2008   #8
I have just bought this problem myself. I find if I engage gear 2 and slip the clutch with handbrake ON, it warms up the clutch plate and dries it out. It's then ok. I had a mini many years ago and replaced the brake linings with 'cheapos' and in damp weather, first braking near sent me through the windscreen as the brakes 'grabbed'. I think the Punto judder is akin to that. It would be interesting to know of different manufacturers clutch linings as comparison.
jimmypickup is offline Reply With Quote Quote
(G) How many Puntos are there on the Forum? - The Thread FiatStiloJTD Punto (Mk2/2b) 543 06-06-2008 17:15
