First Mk1 Punto so bought a CD based Workshop Manual off eBay - would probably have done better with a Haynes manual!
On the inside face of both disks there is 1cm band at the outer edge where the facing material has been eroded leaving a band of rusty crud. Is this a common Punto problem and if so what causes it? Never had it on any other car before.
Is the caliper bolt an 8mm allen/hex? (Manual no help here) Looks like it should be but think I may have broken one in the process of removal. I am sure I read in another post to use a scaffold bar - I only used my socket set!
Anything else I should be aware of??
Many thanks
Clive
Many thanks
Clive
