FIAT Auto Specialist Team
Old 06-09-2021   #1
Question Front slam panel advice
I figure that this piece is called a 'slam panel' but just wanted to confirm. It holds up the front bumper exterior panel and the small plastics bits were broken off (see the yellow arrows). Can anyone confirm that this is the piece?
Can this part be taken from any other Punto's? This is a 2014 Fiat Punto Jet Black 2. I'm located in Oxfordshire.
Any ideas how to fix this would be greatly appreciated.
Thanks for your help,
Conrad
YellowPuntoFiat is offline Reply With Quote Quote
Old 06-09-2021   #2
varesecrazy has donated!
Re: Front slam panel advice
Hi Conrad
Traditionally.. SlamPanel.. is where your bonnet catch is situated
You want to replace..or repair the plastic section you have highlighted?
Charlie .Abingdon
Old 06-09-2021   #3
Hi Charlie,
if I can find a second hand at a good price, then replace would be fine. But whatever is cheaper.
Conrad
Old 07-09-2021   #4
Quote Originally Posted by varesecrazy View Post
Hi Conrad
Charlie .Abingdon
Hi Charlie, do you think that it can be repaired? If so, what are your suggestions?
Thanks,
Conrad
Old 07-09-2021   #5
Quote Originally Posted by YellowPuntoFiat View Post
Thanks,
Conrad
Hi again
Is this proper accident damage..
Or something else..?
Is something left unsupported..or is it just untidy??
IF you get the part number you might find a used one ok..
Old 08-09-2021   #6
Part number... of course. Hopefully it is in an obvious spot. Thanks!
Conrad
Old 16-09-2021   #7
just thought I should close this thread. In the end, I wasn't able to find a used part to replace the broken pieces on the panel. Instead, I fixed the broken plastic with 'plastic welding' techniques. Basically took a soldering iron and re-attached the pieces.
I'll let you know how it holds. But luckily all the pieces were still found and I was able to reconstruct the broken parts. For now, looks pretty solid.
Have a great day,
Conrad
Old 19-09-2021   #8
What has actually caused the damage in the first place, itís quite odd it looks like there is something missing ? Has the car been in any accidents ?
AndyRKett is online now Reply With Quote Quote
(G) Front slam panel needed Hully Punto (2012+) 2 03-05-2020 20:39
(G) Slam panel Fattony81 Doblo 2 12-07-2014 19:53
(T) mk1 slam panel?? SgtRich Punto (Mk1) 5 14-12-2011 17:34
(G) corss memeber / slam panel kimi1984 Bravo / Brava 2 23-04-2007 00:07
(G) Slam Panel black_cinq Cinquecento / Seicento 10 04-03-2005 11:35
