Rhysc89
Hi all,
It's my first post so just straight in with an ask for help really!
I have a 2015 Punto Easy in a 1.4 that I've had nearly 3 years now.
Since I've had it I've had a really annoying issue with the media system. I have the standard cd player system blue and me setup.
This issue only happens after approx 30 minutes of run time. After about this time it then lags. So for example, change volume it's about 5 seconds after pressing any of the buttons/turning the dial the volume changes or it just jumps up to near max. Don't even bother trying to change from radio to bluetooth etc.
This also happens if the key is removed and the engine off and is turned back on within about 10 minutes.
The problem doesn't resolve until the keys been out and engine off for at least 10 minutes.
I've tried going through the update process previously but it gets stuck at the reading process, then when I restart the process I get the as above mentioned lag so it doesn't read it at all.
Has anyone else had this issue or a similar issue?
Thanks in advanced
Thanks in advanced
