General New/replacement gearbox needed. Help :)
VinylHogger
Belfast
So basically my gearbox is banjo'd and needs replaced.
The search function on this forum is so broken but I did try!
It is a 2013 1.2 petrol (8v - 5 Speed).
Does anyone have any good sources for a replacement. I'm thinking brand new is not worth the expense (and I can't afford it anyway) so refurbed might be the way to go.
Any good/trustworthy sources out there I should be looking for?
Thanks!
Thanks guys.
I'm based in Northern Ireland BTW :)
So the Fiat 500 or Alfa Mito 1.2 gearbox will fit a 2013 Punto 1.2 8v?
Can I get confirmation of this somewhere? Part no.?
Thank you!
Hi all,
Thank you for the links. Is there anywhere I can find it written in stone that the gearbox of the Mito/500/Grande will fit this 2013 model Punto?
I would rather not take the risk as I don't want to pay a mechanic for fitting it only to find there is a problem.
Is the part no. what I need? I can't seem to find that anywhere even!
