billy whiz
- Sep 30, 2020
- 8
- 1
hi all im new to puntos but not new to timing belts.
i have a fiat punto easy, its a 1.2 8v 2012 that runs up to 2018 and it was running before i changed the belt now im having issues after changing the timing belt its almost like i have a tooth or two out as its turning over and you can just here that it wants to start but never do? its also poping sometimes when turning over by the key?
ive timed the crankshaft on the bellhousing mark at 0 and used the tool to mark up the camshaft but for some reason now it wont start.
ive changed the crankshaft sensor as it was not talking to the snap on diagnostics computer and sparkplugs were changed aswell. i havent got it 180 degree out as the throttle body is sucking air in and not pushing air out. i turned it over by hand first and no valves were stopping it from turning.
also it has the vvt cam sprocket the one with extra bit on the outside:bang: im sure its called a phonic wheel but not totallly sure?
any ideas would be of great help
