General Abs
General Abs
JAM1905
My abs light is on - I do feel a difference in the breaks - how much does this typically cost?[emoji854]
Hi
There should be several linked systems..
What colour is this light?
It could be a damaged wire.. or rotor
Right through to a full unit :(
Possibly connected to your other electrical issues..?
Ideally you want it looked at..
Reading the ABS and lighting error codes ;)
The abs light is Orange and I get a message on the dash board - I’ve had not comments at MOTs directly about ABS just the light itself
You need to get the abs ECU read and the codes stored will tell you why the light is in, as Charlie said above could be a simple sensor or broken wire, could be the whole abs block.
Literally can’t say anymore than that, the outcome of the test will tell you the likely cost.
