W wenflo New member Joined Dec 7, 2015 Messages 4 Points 2 Aug 11, 2019 #1 Fiat Punto 2010 duological transmission problem. Stuck in 2nd gear. will not start. Will not move. Pls. any help wich solenoid I have to troubleshoot ?
AndyRKett Distinguished member Parked in the garage Joined May 23, 2011 Messages 14,279 Points 3,366 Location Norfolk UK Aug 11, 2019 #2 Can you move the selector. Can you hear the pump prime when you open the door? Have you checked the fuses to make sure that it’s not something simple like the pump fuse has blown. Last edited: Aug 11, 2019
V varesecrazy Patron member Written 10+ guides Joined Apr 27, 2011 Messages 34,979 Points 7,835 Location Near the M4 Aug 12, 2019 #3 wenflo said: Fiat Punto 2010 duological transmission problem. Stuck in 2nd gear. will not start. Will not move. Pls. any help wich solenoid I have to troubleshoot ? Click to expand... Pump is crucial..
