Technical 2013 fiat punto 1.4 no reverse sensors
MrOrange
Turn ignition on, warning comes up on dash for " Parking assistance unavailable"
No beep when putting in reverse,
Reverse light works :)
1 fault code U1724 Parking sensor node (nsp) PRESENT
On the brown plug on control module, If i test CAN wires, I`m getting 4.5v on white wire and 0.8 volts on Blue wire, Are these prone to BCM failing :)
Thanks all
