Hope ive posted in the correct place! I'm after advice on my 2012 fiat punto miltijet lounge.
Just had it recovered from the fiat dealers who have quoted me a whopping £1900 for 4 faulty injectors. Been told that 2 are dumping fuel while the other too aren't letting enough through. I'm concerned that this may be an ecu fault rather than injector.
The car has been regenerating every week for a few months. While regenerating, i need to accelerate hard to move, the revs drop dramatically and if I stop in traffic, stop start cuts out the engine and turns it back on while beeping and flashing the start stop signal. Took it to local garage who couldn't read the ecu, stating that it told him there was an ecu fault and so he couldn't read it. Took it back again after calling the AA out due to the car trying to regen, and the engine cutting out. Garage couldn't diagnose the fault so I took it to fiat. Fiat says no fault codes and advised me of the injector faults. Advised me that it is constantly trying to regen when the engine is turned on. The garage, AA and fiat have all gave me different readings of the amount of regens and how full the dpf filter is. But no fault codes. Worried about spending a fortune on it if this is an ecu fault. I've already had a new battery and relay fitted trying to get to the bottom of this. Anyone had anything similar?
