im Axle Specialists
Old 28-05-2018   #1
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Louie Bee has donated!
Rollin X Pinball Champion, Bubble Bobble Champion
Mozambique
Twin air - check engine & extra warning light.
Hi everyone.
On our way to Skegness the other day we had a loss of boost after crossing the river Trent. Then we noticed an extra warning light over and above the usual check running lamps.
We also noticed the stop start button has a yellow lamp which is also different.
So I didn't want to stop because temp ok, no smoke or nasty noise, we are still moving & it may not restart... Holiday over.
As Emma wanted to stop & check we did. No oil in water no water in oil or burning smell.
Car restarted with a beep check engine & stop start not available. Car drove with boost.
It's probably got a sensor reading out of expected perimeter?
So I'm going to see how the drive is on the way home and use the rac if required.
In the meantime which lead will I need to hook the car to a laptop please?
Thanks all.
Louie Bee is offline Reply With Quote Quote
Old 29-05-2018   #2
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Re: Twin air - check engine & extra warning light.
Is this the lead set I need to plug my Punto ta into a laptop to run multi ECU scan?
Has anyone any experience with this seller? Thanks.
https://m.ebay.co.uk/itm/ALFA-FIAT-D...UAAOSwGzlTxWg4
Old 30-05-2018   #3
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Decided to call rac out and they found 2 fault codes.
No oil pressure (switch was disconnected - 1 cable tie to hold the connector to the body as it was not locking on)
Intermittent fault on the boost pressure sensor - or something like that.
Both codes removed & I no longer have check engine / stop start unavailable errors on startup.
Not driven far so it's early days.
Old 02-06-2018   #4
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Didn't get far before the engine management light came back but drove on.
Boost did not come back this time after turning off the car & re-starting.
Boost came back by it's self after about 50 miles
If it's the same sensor / Error I'm guessing it could be gummed up by blowby oil from the breather circuit. Wishfull thinking maybe but would rather check it out over fitting a new sensor blind only to have the same problem back not too far down the road.
Old 02-06-2018   #5
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Nice picture showing the turbo with the thing plugged into the loom that I think is on my punto...
Looks like part number 55221800
From the picture I can't get my head around it's function.
Old 02-06-2018   #6
varesecrazy has donated!
Hi. Late to this...
I did a test connection to my TA Lsst year.. just uded the ELM327... IIRC
THE MES SITE should detail which extra leads for other functions...
But ENGINE codes are simple.or should be.
Strangely.... my cheap MJ has recurring faults only MES reads them ...
my decent scan tool sees NOTHING..
Charlie
Thanks Louie Bee thanked for this post
Old 02-06-2018   #7
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Thanks for the reply.
Bit odd but the fault has vanished by it's self today.
Only think I can think I did was wiggles the wire going ino the black lump on the turbo when taking a pic of the turbo
If it comes back maybe I need to remove the wire and check for bac connections.
Old 02-06-2018   #8
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Just to add the RAC guy used 1 connection and it went through main EUC and power searing & ABS
came up on the dash what was unavailable and he said that happens as they reader is checking the ECUs.
Wouldn't mind the RAC's laptop as it also had pictures of where stuff is... like how to get to the punto diag socket.
Old 02-06-2018   #9
chris3234 has donated!
Many faults codes will clear themselves after 3 runs without issues
Try running the revs up quite high e.g staying in a lower gear and not changing up till your going faster then you normally would probably the best way of checking faults regarding turbo pressure
chris3234 is offline Reply With Quote Quote
Old 03-06-2018   #10
Maybe RAC Kit is..'intelligent'..
Has software that mimics the old fashioned
SWITCHED KKL .. OR ELM 327 leads..
Just an idea..
Good to hear your TA seems to be behaving.
Charlie
Old 03-06-2018   #11
Quote Originally Posted by varesecrazy View Post
Just an idea..
Charlie
Will be a multiplexed type connection like most professional grade diagnostic systems are can automatically switch the pin connections around to connect to different ECUs
Old 03-06-2018   #12
Thanks.
I had considered using the term..
but only seen the Multiplexed MES in action once... so no great experience.
Old 03-06-2018   #13
Thanks.
We'll that's the only technical type term I could think of for how they work haha
Old 16-06-2018   #14
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Dare I say the twinAir has been OK - no warning lamp has come back on since
Well apart from the usual "check running lights", but that's normal
Old 16-06-2018   #15
Quote Originally Posted by Louie Bee View Post
Good stuff.
Is it running LED bulbs or something?
No warnings from mine..
In other news..
Did see its sister car the other day
(The one that the dealership used as a donor for other cars missing trim.. YES-REALLY..!!)
It only had 1 cornering light
.bit strange.. maybe MOT issue?
(T) Check Engine Warning Light SikWitIt123 Grande Punto 13 16-11-2017 14:45
(T) Check Engine Light And Warning Harvz Grande Punto 1 22-07-2013 14:33
check engine & warning light on jon0048 Lets Talk FIAT 2 02-01-2012 18:56
(G) Warning Light With Check Engine Rothy Bravo 7 23-03-2011 18:47
