Old 16-06-2018   #16
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Louie Bee has donated!
Rollin X Pinball Champion, Bubble Bobble Champion
Mozambique
Re: Twin air - check engine & extra warning light.
Standard bulbs all round. LED strips in the rear clusters for tail lights.
think the LED driver board on the N/S/R smelt a bit burned out when I looked last year - but it's working OK.
Can't bring mysels to shell out for a new unit for the sake of a 5p SMD transistor I can't get to.
The new unit would only fill mith mist and do the same?
What a shame a good green Punto being parted for spares.
Louie Bee is offline Reply With Quote Quote
Old 17-06-2018   #17
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Bugger. Spoke too soon. During a trip to Wales the error returned. Back to no boost.
No fun 850cc nat asp
Old 19-06-2018   #18
varesecrazy has donated!
Can you read codes: sensor data?
Old 19-06-2018   #19
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
The elm327 arrived today along with the adapters. https://m.ebay.co.uk/itm/ALFA-FIAT-D...336933fff75119
When I sussed the config The software said I need to register to use it & would only run simulation. Was using the green adapter.. not sure that's right.
Waiting on a laptop as this setup ain't too easy
Old 19-06-2018   #20
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
This setup & it connected to the car when plugged in eventually
Old 19-06-2018   #21
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Got it wrong...
http://www.multiecuscan.net/SupportedVehiclesList.aspx
The green block is for the interface (eg elm327) (not the green adapter). The red box with A3 denotes which colour adapter A3 (yellow adapter).
Will try again tomorrow lol.
That's better than thinking simulation was read only non licenced version + looking to fix non real codes p068a-86 and b0110-15
Old 20-06-2018   #22
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Nope the mes free version will not connect to any module on my Punto twin air. It tells me which colour adapter I need but every function ends like this
Name:	2018-06-20 17_30_10-Multiecuscan 3.7 - FREE at www.multiecuscan.net.jpg
Old 20-06-2018   #23
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
However I can connect with the panda abs & engine ECUs. Even delete a code. But not the panda power steering ECM. That's restricted to registered version.
Old 20-06-2018   #24
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Ok just noticed the note on message about ECUs in black are supported by the free version, but in red are not... So almost nothing is covered for Punto ta in the free version.
Best hurry up and get a laptop.
Old 20-06-2018   #25
Quote Originally Posted by Louie Bee View Post
shame you are 200 miles away..
Cardiff / Oxford
Old 20-06-2018   #26
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
have to stand on my own two feet
Just noticed that the single licence can be transfered to other PCs up to 10 times. "The License Transfer function has a limitation of 1 transfer per month and a total of 10 transfers."
maybe have a go at registering tonight when the kids have settled.
Old 20-06-2018   #27
Moderator
g8rpi's Avatar
g8rpi has donated!
Any laptop running Windows XP or later will work OK. It does not hve to be expensive, I've even used one I got for nothing on Freecycle.
Robert G8RPI.
Thanks Louie Bee thanked for this post
g8rpi is offline Reply With Quote Quote
Old 21-06-2018   #28
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Here are the codes
Old 21-06-2018   #29
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Oh bugger... P0244-62 could result in a new turbo???
Old 21-06-2018   #30
Moderator
g8rpi's Avatar
g8rpi has donated!
Don't panic or jump to conclusions Check for loose connectors on the ECU and body computer first. At least unplug and re-plug them. Then clear the codes and see if they come back. If they come back you need to look at the engine parameters like mass air flow and boost pressure. MES will record parameters while you go for a test drive.
Robert G8RPI.
Likes Louie Bee liked this post
(T) Check Engine Warning Light SikWitIt123 Grande Punto 13 16-11-2017 14:45
(T) Check Engine Light And Warning Harvz Grande Punto 1 22-07-2013 14:33
check engine & warning light on jon0048 Lets Talk FIAT 2 02-01-2012 18:56
(G) Warning Light With Check Engine Rothy Bravo 7 23-03-2011 18:47
